Administration panel¶
A number of monitoring and configuration options are available through the admin panel to administer your instance without needing to open config files on the server.
The admin panel is available to administrator users (see Add other administrators).
User Menu (avatar at the top right) > Administration
or go to https://your-instance.com/admin/
This page repeats the comments present on the admin panels and adds a few clarifications.
General¶
The following fields are used to describe the instance in the list of public instances and is shown on your instance front page.
Instance name¶
The name displayed for this instance
Instance description¶
The descriptive text displayed for this instance
Admin contact email¶
This email address is displayed on the instance contact page.
This email may be used by the development team, only if Consent to contact is given, to warn of security vulnerabilities or in other cases for example matters affecting public facing instances listed in the directory.
Hosting location¶
The country where this instance's encrypted data is hosted.
Flush HTTP Cache¶
Force users to download the latest client-side assets (only if your server is in fresh mode).
This includes some configuration changes distributed via /api/config.
Customize¶
Upload Logo¶
Browse local files on your computer to upload a logo for your CryptPad instance. Maximum size is 200KB. File formats supported are:
SVG
PNG
JPG
Click RESTORE DEFAULT button to restore the official CryptPad logo instead of the customized one.
Accent color¶
Change the accent color of your CryptPad instance. Please ensure text and buttons are readable with sufficient contrast in both light and dark themes.
Use the color picker to select the color you want then click the CHANGE COLOR button. You can RESTORE DEFAULT with the red button.
You can see the preview of the color selected with a link and the two kind of buttons in CryptPad.
Administrators¶
This section is used to manage administrators of the instance.
Current administrators¶
View and remove current administrators.
Add administrators¶
Add administrators from their public key or from your contacts list.
Broadcast¶
This section offers different ways of sending notifications to all users on the instance.
Homepage notice¶
An optional message to display on the home page.
Maintenance¶
Plan a maintenance on this instance and notify all users. Limited to one active maintenance at a given time.
Survey¶
Add, update or remove a link to an external survey. Users will receive a notification and the survey will remain available from the user menu.
Broadcast Message¶
Send a message to all users on this instance. All existing and new users will receive it as a notification. Preview messages before sending them with "Preview notification". Preview notifications have a red icon and are visible only to you.
Security¶
Enable remote embedding¶
Allow documents and media from this instance to be embedded on other websites. This will add an "Embed" option to the Share menu. For security reasons applications that use OnlyOffice (Sheets, Document, Presentation) cannot be embedded even if this setting is active.
Please note that by enabling this settings, you will need to adapt your Nginx configuration file, adding vector: to pass diagnostic tests.
Mandatory Two-Factor Authentication¶
Tick the box so all users on this instance will be asked to set up two-factor authentication to log in to their account.
Applications¶
Instance applications¶
Choose which apps to enable on this instance. Enable or disable the ones you want and hit the SAVE button.
User Directory¶
Close registration¶
Do not allow any new users to register.
Invitation Links¶
Invitation links create one account each, even if registration is closed. User name and email are for your identification purposes only. CryptPad will not email the invitation link (or anything else), please copy the link and send it using the secure channel of your choice.
User Directory¶
List of known accounts on this instance. Select options to add invited accounts automatically, or enter information manually using the form.
You can toggle the two following options (enabled by default):
Automatically store invited users
Automatically store SSO users
User Storage¶
This section is for managing storage limits on the instance.
The values set in the admin panel override the defaults or modifications made to the configuration files.
Storage Limit¶
Maximum storage limit for CryptDrives (users and teams) when no custom rule is applied.
Apply a custom limit¶
Set custom limits for users by using their public key. You can update or remove an existing limit.
Custom limits¶
List all the custom storage limits applied to your instance.
Database¶
This section is dedicated for the database management. You will find moderation tools and specific information about the accounts registered.
Account information¶
Enter a user's public key to fetch data about their account. Click the GENERATE REPORT button, when it's done, you can access the following information:
Report timestamp: the time and date when the report was made
Public Signing Key: the public key of the user
First pin activity time: the time and date when the user registered their account
Last pin activity time: the last time the user modified their account, teams, folders or documents
Is currently online: if the user is currently online (true of false)
Plan name: if the user has a paid subscription, the type of plan subscribed
Plan note: a note left by an administrator if a plan is gifted to the user
Storage limit: the storage quota for the user
Data stored: the actual storage usage
Pin log is available: if the account is usable (true or false)
Pin log is archived: if the account is archived (true of false)
Current pin list: click the FETCH button to generate the list of all pinned teams, folders and documents
Archive this account (Including its owned documents): click the ARCHIVE button to delete the account of the user.
You must then fill a popup with a text field to register the reason for the archival.
Report content (JSON), This feature is considered experimental: click the COPY TO CLIPBOARD button to gather informations about the user in the JSON format
The Archive this account functionality is how you can moderate your CryptPad instance. Removing unwanted accounts, those not respecting your Terms of Service, breaking the laws where you operate your instance or simply when an user ask for their account removal.
Document information¶
Query a document or file via its id or URL. Click the GENERATE REPORT button, when it's done, you can access the following information:
Document identifier: the identifier code of the document
Document type: either Document for a realtime document or File for a static file (image, audio, PDF file, etc)
Document size: the size of the document in megabyte
Current metadata: metadata of the document formatted in JSON
Metadata history: click the FETCH button to show the history of the document
Created: the time and date when the document was created
Last modified: the time and date when the document was modified for the last time
Currently open: shows if the document is currenlty accessed by someone (true or false)
Available: shows if the document can be accessed (true or false)
Archived: tells you if the document has been archived or not (true or false)
Archive document: click the ARCHIVE button to delete the document.
It makes a document unavailable without deleting it permanently.
It will be placed in an archive directory and deleted after a few days (configurable in the server configuration file).
Report content (JSON), This feature is considered experimental: click the COPY TO CLIPBOARD button to gather informations about the document in the JSON format
Just like the Archive this account functionality, the Archive document one is used to moderate your CryptPad instance. Removing unwanted content, the kind not respecting your Terms of Service, breaking the laws where you operate your instance or simply when an owner ask for its removal.
Login-block information¶
The login block is what allows an account to log in to CryptPad with the combination of username + password
2FA Recovery¶
Users can copy recovery data on the 2FA recovery page https://your-instance.com/recovery/ in the "Forgot recovery code" section and email it to the instance administrators. Paste recovery data below to disable 2FA for an account
Support¶
Initialize support¶
Create or update the support keys.
Manage support team¶
Add and remove people from the instance support team.
Statistics¶
Launch time: Date and time at which the server was launched
Active connections: Number of active websocket connections (and unique IP addresses connected)
Active documents: Number of unique documents currently being viewed or edited
Open Files: Number of file descriptors currently open on the server
Registered users: Number of users registered on your instance
Disk usage: Amount of storage space consumed by various CryptPad resources
Предупреждение
The disk usage report can be very resource intensive to run on large instances.
Performance¶
This section is dedicated to available measurments for checking resources consumption.
Performance¶
An overview of the total time spent executing various server-side commands
Measure disk performance¶
If enabled, a JSON API endpoint will be exposed under /api/profiling. This keeps a running measurement of disk I/O within the time window set below. This setting can impact server performance and may reveal sensitive data. It is recommended that you leave this setting disabled unless you know what you are doing.
Disk performance measurement window¶
If you have enabled disk performance measurements then the duration of the window can be configured below.
Network¶
Validate instance configuration¶
CryptPad includes a page which automatically diagnoses common configuration issues and suggests how to correct them if necessary. To visit the page use the Run Diagnostics button or visit https://your.instance/checkup/.
The rest of this section includes options about how you and your instance communicate, or not, with the CryptPad development team.
Server telemetry¶
Opt-out of daily messages sent from the instance to the development team's server. The purpose of these messages is to count how many third-party instances of CryptPad are in operation and which version of the software they are running. The full content of the messages can be reviewed in CryptPad's server logs.
Statistical aggregation¶
You may opt-in to providing additional usage metrics to the developers, such as the approximate number of registered and daily users for your instance.
List my instance in public directories¶
Opt-in to have the instance included in the list of public instances on the CryptPad project site if it is intended for public use. We add public instances to our uptime monitoring and encourage administrators to follow updates.
In addition to this setting being enabled, the following criteria are required in order to have an instance listed:
All diagnostic tests must pass
Must not use a domain such as cryptpad.TLD as they imply a relationship with the development team and copyright holder (XWiki SAS), please use a subdomain instead
The version of CryptPad must be up to date within 90 days of the latest release
Instance information must be provided in the General tab
Server telemetry must be enabled
Absence of analytics and third-party trackers
Reasonable uptime, ±99% average availability on the previous 30 days
A working backup strategy is in place and has been tested
At least one other person must have access to the infrastructure
Commitment to give users at least 6 months of advance warning in case of shutting down
The list of public instances is considered an extension of the CryptPad community. As such, the development team reserves the right to remove instances from the list if their administrators or the groups they represent are in breach of the Code of Conduct or for any other reason at their own discretion.
Consent to contact¶
Opt-in to allow the development team to contact the Admin contact email with notifications of serious problems with the software or the instance configuration. Administrator emails are never shared, sold, or used for marketing purposes.
Crowdfunding participation¶
Opt-out of advertizing CryptPad's crowdfunding campaign on the instance.
Instance purpose¶
Indicate the purpose of the instance, this is used to inform the development roadmap.
Instance purpose is only sent to the development team if Server telemetry is enabled
